System Administration Guide: Resource Management and Network Services
How to Access the Resource Controls Tab
The Resource Controls tab is located under System Configuration in the Navigation pane. To access Resource Controls, do the following:
  1. Click the System Configuration control entity in the Navigation pane.
  2. Double-click Projects.
  3. Click on a project in the console main window to select it.
  4. Select Properties from the Action menu.
  5. Click the Resource Controls tab.
    View, add, edit, or delete resource control values for processes, projects, and tasks.
