As superuser, type prctl to display the maximum file descriptor for the current shell that is running:
# prctl -n process.max-file-descriptor $$
8437: sh
process.max-file-descriptor [ lowerable deny ]
256 basic deny
65536 privileged deny
2147483647 system deny
Use the prctl command to temporarily add a new privileged value to deny the use of more than three LWPs per task for the x-files project. The result is identical to the result in "How to Set the Maximum Number of LWPs for Each Task in a Project", as shown in the following annotated sample session:
# newtask -p x-files
# id -p
uid=0(root) gid=1(other) projid=101(x-files)
# prctl -n task.max-lwps -t privileged -v 3 -e deny -i project x-files
# prctl -n task.max-lwps -i project x-files
670: sh
task.max-lwps
3 privileged deny
You can also use prctl -r to change the lowest value of a resource control.
# prctl -n process.max-file-descriptor -r -v 128 $$ |
