System Administration Guide: Resource Management and Network Services
How to Display Extended Accounting Status
Type acctadm without arguments to display the current status of the extended accounting facility.
# acctadm
                 Task accounting: active
            Task accounting file: /var/adm/exacct/task
          Tracked task resources: extended
        Untracked task resources: none
              Process accounting: active
         Process accounting file: /var/adm/exacct/proc
       Tracked process resources: extended
     Untracked process resources: host,mstate
                 Flow accounting: active
            Flow accounting file: /var/adm/exacct/flow
          Tracked flow resources: extended
        Untracked flow resources: none
In the previous example, system task accounting is active in extended mode and mstate mode. Process and flow accounting are active in extended mode.
Note -
In the context of extended accounting, microstate (mstate) refers to the extended data, associated with microstate process transitions, that is available in the process usage file (see proc(4)). This data provides much more detail about the activities of the process than basic or extended records.
