Use ps -o to display task and project IDs. For example, to view the project ID, type the following:
# ps -o user,pid,uid,projid USER PID UID PROJID jtd 89430 124 4113 |
Use id -p to print the current project ID in addition to the user and group IDs. If the user operand is provided, the project associated with that user's normal login is printed:
# id -p uid=124(jtd) gid=10(staff) projid=4113(booksite) |
To match only processes with a project ID in a specific list, type the following:
# pgrep -J projidlist # pkill -J projidlist |
To match only processes with a task ID in a specific list, type the following:
# pgrep -T taskidlist # pkill -T taskidlist |
To display various statistics for processes and projects that are currently running on your system, type the following:
% prstat -J PID USERNAME SIZE RSS STATE PRI NICE TIME CPU PROCESS/NLWP 21634 jtd 5512K 4848K cpu0 44 0 0:00.00 0.3% prstat/1 324 root 29M 75M sleep 59 0 0:08.27 0.2% Xsun/1 15497 jtd 48M 41M sleep 49 0 0:08.26 0.1% adeptedit/1 328 root 2856K 2600K sleep 58 0 0:00.00 0.0% mibiisa/11 1979 jtd 1568K 1352K sleep 49 0 0:00.00 0.0% csh/1 1977 jtd 7256K 5512K sleep 49 0 0:00.00 0.0% dtterm/1 192 root 3680K 2856K sleep 58 0 0:00.36 0.0% automountd/5 1845 jtd 24M 22M sleep 49 0 0:00.29 0.0% dtmail/11 1009 jtd 9864K 8384K sleep 49 0 0:00.59 0.0% dtwm/8 114 root 1640K 704K sleep 58 0 0:01.16 0.0% in.routed/1 180 daemon 2704K 1944K sleep 58 0 0:00.00 0.0% statd/4 145 root 2120K 1520K sleep 58 0 0:00.00 0.0% ypbind/1 181 root 1864K 1336K sleep 51 0 0:00.00 0.0% lockd/1 173 root 2584K 2136K sleep 58 0 0:00.00 0.0% inetd/1 135 root 2960K 1424K sleep 0 0 0:00.00 0.0% keyserv/4 PROJID NPROC SIZE RSS MEMORY TIME CPU PROJECT 10 52 400M 271M 68% 0:11.45 0.4% booksite 0 35 113M 129M 32% 0:10.46 0.2% system Total: 87 processes, 205 lwps, load averages: 0.05, 0.02, 0.02 |
To display various statistics for processes and tasks that are currently running on your system, type the following:
% prstat -T PID USERNAME SIZE RSS STATE PRI NICE TIME CPU PROCESS/NLWP 23023 root 26M 20M sleep 59 0 0:03:18 0.6% Xsun/1 23476 jtd 51M 45M sleep 49 0 0:04:31 0.5% adeptedit/1 23432 jtd 6928K 5064K sleep 59 0 0:00:00 0.1% dtterm/1 28959 jtd 26M 18M sleep 49 0 0:00:18 0.0% .netscape.bin/1 23116 jtd 9232K 8104K sleep 59 0 0:00:27 0.0% dtwm/5 29010 jtd 5144K 4664K cpu0 59 0 0:00:00 0.0% prstat/1 200 root 3096K 1024K sleep 59 0 0:00:00 0.0% lpsched/1 161 root 2120K 1600K sleep 59 0 0:00:00 0.0% lockd/2 170 root 5888K 4248K sleep 59 0 0:03:10 0.0% automountd/3 132 root 2120K 1408K sleep 59 0 0:00:00 0.0% ypbind/1 162 daemon 2504K 1936K sleep 59 0 0:00:00 0.0% statd/2 146 root 2560K 2008K sleep 59 0 0:00:00 0.0% inetd/1 122 root 2336K 1264K sleep 59 0 0:00:00 0.0% keyserv/2 119 root 2336K 1496K sleep 59 0 0:00:02 0.0% rpcbind/1 104 root 1664K 672K sleep 59 0 0:00:03 0.0% in.rdisc/1 TASKID NPROC SIZE RSS MEMORY TIME CPU PROJECT 222 30 229M 161M 44% 0:05:54 0.6% group.staff 223 1 26M 20M 5.3% 0:03:18 0.6% group.staff 12 1 61M 33M 8.9% 0:00:31 0.0% group.staff 1 33 85M 53M 14% 0:03:33 0.0% system Total: 65 processes, 154 lwps, load averages: 0.04, 0.05, 0.06 |
The -J and -T options cannot be used together.
