The following table describes new command-line options for sendmail. Other command-line options are described in the sendmail(1M) man page.
Table 27-1 New Command-Line Options for sendmail|
Option |
Description |
Indicates that you want to use the configuration file, submit.cf, even if the operation mode does not indicate an initial mail submission. For more information about submit.cf, refer to "New Configuration File, submit.cf". |
Indicates that you want to use the configuration file, sendmail.cf, even if the operation mode indicates an initial mail submission. For more information, refer to "New Configuration File, submit.cf". |
Indicates that you are printing the number of entries in each queue. |
Indicates that the message that is being submitted from the command line is for relaying, not for initial submission. The message is rejected if the addresses are not fully qualified. No canonicalization is done. As is noted in the Release Notes that are part of the sendmail distribution on ftp://ftp.sendmail.org, improperly formed messages might be rejected in future releases. |
Sets the identifier that is used for syslog messages to the supplied tag. |
Processes only jobs that contain this substring of one of the recipients. When ! is added, the option processes only jobs that do not have this substring of one of the recipients. |
Processes only jobs that contain this substring of the queue ID. When ! is added, the option processes only jobs that do not have this substring of the queue ID. |
Processes only jobs that contain this substring of the sender. When ! is added, the option processes only jobs that do not have this substring of the sender. |
Processes saved messages in the queue once, without using the fork system call, and runs the process in the foreground. Refer to the fork(2) man page. |
Processes only the messages in the name queue group. |
Processes saved messages in the queue at a specific interval of time with a single child that is forked for each queue. The child sleeps between queue runs. This new option is similar to the -qtime, which periodically forks a child to process the queue. |
As is noted in the Release Notes that are part of the sendmail distribution on ftp://ftp.sendmail.org, this option is not available in version 8.12. Mail user agents should use the -G argument. |
