The new ClientPortOptions option is for outgoing connections and is similar to the DaemonPortOptions option. This option sets the client SMTP options, which are a sequence of key=value pairs. To declare this option, use one of the following syntaxes. For formatting purposes, the example includes two pairs. However, you can apply one or more pairs.
O ClientPortOptions=pair,pair # for the configuration file -OClientPortOptions=pair,pair # for the command line define(`confCLIENT_OPTIONS',`pair,pair') # for m4 configuration |
If you need to build a new sendmail.cf file, refer to "Building the sendmail.cf Configuration File (Task)" in Chapter 25, Mail Services (Tasks).
The following table describes the new keys for this option.
Table 27-4 New Keys for ClientPortOptions|
Key |
Description |
Addr |
Specifies the address mask. The value can be a numeric address in dot notation or a network name. If the pair is omitted, the default is INADDR_ANY, which accepts connections from any network. |
Family |
Specifies the address family. The key's default is inet for AF_INET. Other values are inet6 for AF_INET6, iso for AF_ISO, ns for AF_NS, and x.25 for AF_CCITT. |
Listen |
Specifies the size of the listen queue. The key defaults to 10. You should not have to change this default for the Solaris operating environment. |
Port |
Specifies the name and number of the listening port. The key defaults to smtp. |
RcvBufSize |
Specifies the size of the TCP/IP send buffer. The key has no default value, which means that no size specifications are automatically made. If the option is set to a value greater than zero, that value is used. You should not have to limit the size of this buffer for the Solaris operating environment. |
Modifier |
Specifies flags for sendmail: The h flag uses the name that corresponds to the outgoing interface address for the HELO or EHLO commands, whether it was chosen by the connection parameter or by the default. The A flag disables AUTH. This flag can also be used with the Modifier key for DaemonPortOptions. Refer to "Changes to DaemonPortOptions Option". The S flag turns off the use of or the offer to use STARTTLS when email is being delivered or received. |
