System Administration Guide: Resource Management and Network Services
How to Check for Faulty Modems or ACUs
You can check if the modems or other ACUs are not working properly in several ways.
  1. Obtain counts and reasons for contact failure by running the following command:
    # uustat -q
  2. Call over a particular line and print debugging information on the attempt.
    The line must be defined as direct in the /etc/uucp/Devices file. (You must add a telephone number to the end of the command line if the line is connected to an autodialer or the device must be set up as direct.) Type:
    # cu -d -lline
    line is /dev/cua/a.
