System Administration Guide: Resource Management and Network Services
How to Control Uploads to the FTP Server
Add the directives to the ftpaccess file to specify upload permissions and error messages for upload failures.
  1. Become superuser.
  2. Add the following entries to the ftpaccess file.
    To enable users to upload files, add the following entry:
    upload [absolute|relative] [class=<classname>]... [-] root-dir \
    dirglob yes|no owner group mode [dirs|nodirs] [<d_mode>]
    path-filter typelist mesg allowed_charset {disallowed regexp...}
    upload
    Keyword that is applied to users who have a home directory (the argument to chroot()) of the root-dir . The root-dir can be specified as "*" to match any home directory.
    absolute|relative
    Parameter that specifies whether the root-dir directory paths are interpreted as absolute or relative to the current chroot directory.
    class
    Keyword that is used to specify any number of class=<classname> restrictions. If restrictions are specified, the upload clause only becomes effective if the current user is a member of one of the specified classes.
    root-dir
    User's root directory and the home directory for anonymous users.
    dirglob
    A pattern to match a directory name. An asterisk can be used in any place or alone to signify any directory.
    yes|no
    Variable that allows or disallows upload to the FTP server.
    owner
    Owner of files that are uploaded into dirnames.
    group
    Group that is associated with files that are uploaded into dirnames.
    mode
    Parameter that is used to specify access permissions for uploaded files. The default mode 0440 prevents the anonymous account from reading uploaded files.
    dirs|nodirs
    Keyword that allows or disallows users to create subdirectories in a directory that is listed in dirnames.
    d_mode
    Optional mode that determines the permissions for a newly created directory.
    path-filter
    Keyword that controls the names of uploaded files.
    typelist
    A comma-separated list of any of the keywords "anonymous," "guest," and "real."
    mesg
    Message file that is displayed fails to match the regexp criteria.
    Alphanumeric characters allowed or disallowed in file names.
Example-Controlling Uploads to the FTP Server
upload /export/home/ftp /incoming yes ftpadm ftpadmin 0440 nodirs
path-filter anonymous /etc/ftpd/filename.msg ^[-A-Za-z0-9._]*$ ^[.-]
The preceding example states the following:
Note -
Ownership and permissions on a directory into which anonymous uploads are allowed should be tightly controlled. The FTP Administrator should be the owner of all files uploaded to the FTP server. You need to create an FTP Administrator when anonymous users are allowed to upload files. The directory should be owned by the user ftpadm and group ftpadm with permissions set to 3773.
The access mode for files uploaded to the FTP server should be 0440. The 0440 mode prevents the anonymous account from reading uploaded files. This restriction protects your server from becoming a staging area for third-party file distribution.
To make uploaded files available for distribution, the FTP Administrator can move files to a public directory.
