System Administration Guide: Security Services
exit Token
The exit token records the exit status of a program. The exit token contains the following fields:
The praudit command displays the exit token as follows:
exit,Error 0,0
The following figure shows the format of an exit token.
Figure 26–10 exit Token Format
The preceding context describes the graphic.
