System Administration Guide: Security Services
header Token
The header token is special in that it marks the beginning of an audit record and combines with the trailer token to bracket all the other tokens in the record. The header token has six fields:
On 64-bit systems, the header token is displayed with a 64-bit time stamp, in place of the 32-bit time stamp.
The praudit command displays the header token for a ioctl() system call as follows:
header,240,1,ioctl(2),es,Tue Sept  1 16:11:44 2001, + 270000 msec
The following figure shows the format of a header token.
Figure 26–13 header Token Format
The preceding context describes the graphic.
The ID modifier field has the following flags defined:
0x4000			PAD_NOTATTR						nonattributable event
0x8000			PAD_FAILURE						fail audit event
