System Administration Guide: Security Services
path Token
The path token contains access path information for an object. This token contains the following fields:
The praudit command displays the path token as follows. Note that the path length field is not displayed.
path,/etc/security/audit_user
The following figure shows the format of a path token.
Figure 26–21 path Token Format
The preceding context describes the graphic.
