System Administration Guide: Security Services
seq Token
The seq token (sequence token) is an optional token that contains a sequence number. Used for debugging, this token is added to each audit record when the seq policy is active. The seq token has two fields:
The sequence number is incremented every time an audit record is generated and added to the audit trail. The praudit command displays the seq token as follows:
sequence,1292
The following figure shows the format of a seq token.
Figure 26–24 seq Token Format
The preceding context describes the graphic.
Note –
The seq token is output only when the seq audit policy is active.
