System Administration Guide: Security Services
attr Token
The attr token contains information from the file vnode. This token has seven fields:
See the statvfs(2) man page for further information about the file system ID and the device ID.
The attr token usually accompanies a path token and is produced during path searches. In the event of a path-search error, the attr token is not included as part of the audit record since there is no vnode available to obtain the necessary file information. The praudit command displays the attr token as follows:
attribute,100555,root,staff,1805,13871,-4288
The following figure shows the format of an attr token.
Figure 26–7 attr Token Format
The preceding context describes the graphic.
