System Administration Guide: Security Services
Example—Running ASET Interactively
The following example shows ASET being run at low security with the default working directory.
# /usr/aset/aset -l low
======= ASET Execution Log =======
ASET running at security level low
Machine = jupiter; Current time = 0111_09:26
aset: Using /usr/aset as working directory
Executing task list ...
	firewall
	env
	sysconf
	usrgrp
	tune
	cklist
	eeprom
All tasks executed. Some background tasks may still be running.
Run /usr/aset/util/taskstat to check their status:
 /usr/aset/util/taskstat [aset_dir]
where aset_dir is ASET's operating
directory,currently=/usr/aset.
When the tasks complete, the reports can be found in:
 /usr/aset/reports/latest/*.rpt
You can view them by:
 more /usr/aset/reports/latest/*.rpt
