System Administration Guide: Security Services
Example—Forcing a Deallocation
Devices that a user has allocated are not automatically deallocated when the process terminates or when this user logs out. You most commonly need to use the following form of the deallocate command when a user forgets to deallocate a specific device. Then you force its deallocation, so that others users can allocate it.
# deallocate -F st0
