System Administration Guide: Security Services
Example—Setting the cnt Policy
The cnt policy can be set so that if the audit partitions become full, then processes are not blocked. The records are discarded when the partitions are full, but the system still functions even though the auditing process is not recording the events. The cnt policy should not be set if security is paramount, since unrecorded events can occur if the file system is full.
The following command enables the cnt policy:
# auditconfig -setpolicy +cnt
For a secure site, you should enable the cnt policy in an appropriate startup file.
