System Administration Guide: Security Services
Preventing Unintentional Misuse of Machine Resources
You can prevent you and your users from unintentional error. You can keep from running a Trojan horse by setting the PATH variable correctly. You can prevent user error by steering users to those parts of the system that the users need for their jobs. In fact, through careful setup, you can ensure that users see only those parts of the system that help the users work efficiently.
Setting the Path Variable
You should take care to set the path variable correctly. Otherwise, you can accidentally run a program that was introduced by someone else. The intruding program can corrupt your data or harm your system. This kind of program, which creates a security hazard, is referred to as a “Trojan horse.” For example, a substitute su program could be placed in a public directory where you, as system administrator, might run the substitute program. Such a script would look just like the regular su command. Since the script removes itself after execution, you would have little evidence to show that you have actually run a Trojan horse.
The path variable is automatically set at login time. The path is set through the startup files: .login, .profile, and .cshrc. When you set up the user search path so that the current directory (.) comes last, you are protected from running this type of Trojan horse. The path variable for superuser should not include the current directory at all.
The Automated Security Enhancement Tool (ASET) examines the startup files to ensure that the path variable is set up correctly. ASET also makes sure that the path variable does not contain a dot (.) entry.
Assigning a Restricted Shell
The standard shell allows a user to open files, execute commands, and so on. The restricted shell is invoked with the /usr/lib/rsh command. The restricted shell can be used to limit the ability of a user to change directories and to execute commands. Note that the restricted shell is not the remote shell, which is /usr/sbin/rsh. The restricted shell differs from the standard shell in the following ways:
The restricted shell enables you to limit a user's ability to stray into the system files. The shell creates a limited environment for a user who needs to perform specific tasks. The restricted shell is not completely secure, however, and is only intended to keep unskilled users from inadvertently doing damage.
For information about the restricted shell, see the rsh(1M) man page.
A more secure alternative to the restricted shell is the Secure Shell, the ssh command. The Secure Shell enables users to securely access a remote host over an unsecured network. For information about using the Secure Shell, see Chapter 6, Secure Shell Administration (Reference).
Restricting Access to Data in Files
Since the Solaris operating environment is a multiuser environment, file system security is the most basic security risk on a system. You can use the traditional UNIX file protection to protect your files. You can also use the more secure access control lists (ACLs).
After you have established login restrictions, you can control access to the data on your machine. You might want to allow some users to read some files, and give other users permission to change or delete some files. You might have some data that you do not want anyone else to see. Chapter 16, Securing Files (Tasks) discusses how to set file permissions.
