System Administration Guide: Security Services
RBAC Database Relationships
The following figure illustrates how the RBAC databases work together.
Figure 20–1 RBAC Database Relations
Diagram shows data flow from exec_attr and auth_attr to prof_attr, which in turn flows to user_attr and policy.conf file, then to the user or role.
The user_attr database stores the basic definitions for both users and roles, which are differentiated by the type field. The user_attr database contains the attributes that are shown in the figure, which includes a comma-separated list of rights profile names. The definitions of the rights profiles are split between two databases. The prof_attr database contains rights profile identification information, authorizations that are assigned to the profile, and supplementary profiles. The exec_attr database identifies the security policy and contains commands with their associated security attributes. The auth_attr database supplies authorization information to the Sun Management Console tools. The policy.conf database supplies default authorizations and rights profiles that are to be applied to all users.
Each database uses a key=value syntax for storing attributes. This method accommodates future expansion of the databases and enables a system to continue if it encounters a key that is unknown to its policy.
The scope of the RBAC databases can apply to individual hosts or to all hosts that are served by a name service such as NIS, NIS+, or LDAP. The precedence of local configuration files versus distributed databases for the user_attr database is set by the precedence that is specified for the passwd entry in the file /etc/nsswitch.conf. The precedence for the prof_attr and auth_attr databases are individually set in /etc/nsswitch.conf. The exec_attr database uses the same precedence as prof_attr. For example, if a command with security attributes is assigned to a profile that exists in two scopes, only the entry in the first scope is used.
The databases can reside on a local system or can be administered by the NIS, NIS+, or LDAP name service.
You can edit the databases manually or manipulate them with the commands that are described in Command-Line Applications for Managing RBAC.
