If you upgrade to the Solaris 9 9/02 operating environment on a system running the Solaris 9 Beta Refresh operating environment with Simplified Chinese or Traditional Chinese locale support, the upgrade does not complete successfully. The Simplified Chinese and Traditional Chinese CDE font localization packages (SUNWcdft or SUNWhdft) do not upgrade to the appropriate Solaris 9 9/02 packages. The following error message is displayed.
Removing package SUNWcdft: /a/var/sadm/pkg/SUNWcdft/install/postremove: /a/usr/dt/config/xfonts/zh_CN.EUC: does not exist /a/var/sadm/pkg/SUNWcdft/install/postremove: /a/usr/dt/config/xfonts/zh_CN.GBK: does not exist /a/var/sadm/pkg/SUNWcdft/install/postremove: /a/usr/dt/config/xfonts/zh_CN.UTF-8: does not exist pkgrm: ERROR: postremove script did not complete successfully |
Workaround: Before you upgrade to the Solaris 9 9/02 operating environment, remove the appropriate Solaris 9 Beta Refresh postremove files.
# rm /var/sadm/pkg/SUNWcdft/install/postremove # rm /var/sadm/pkg/SUNWhdft/install/postremove |
