If you use the Solaris 9 9/02 Installation CD with certain locales, the installation program does not prompt you to install packages from the Solaris 9 9/02 Documentation 2 of 2 CD. This problem occurs for the following locales.
ja_JP.PCK
ja_JP.UTF-8
ko.UTF-8
zh.GBK
zh.UTF-8
zh_CN.18030
zh_HK.BIG5HK
zh_HK.UTF-8
zh_TW.BIG5
zh_TW.UTF-8
Workaround: Choose one of the following workarounds.
Select one of the EUC locales (ja, ko, zh or zh_TW) as the default installation locale when you install the Solaris 9 9/02 software.
Run the installer utility directly from the Solaris 9 9/02 Documentation 2 of 2 CD.
