If you use the -s option with the luupgrade command to add patches with a directory and a patch list file, the patches are not added. A message similar to the following message is displayed:
/usr/sbin/luupgrade [52]: 3 patch-list-file: bad number |
In the previous message, patch-list-file is the patch list file you specified for the luupgrade command to use to add patches.
Workaround: To add patches specifying a patch list file, perform the following steps.
Become superuser.
Mount the boot environment that you want to patch.
# lumount boot-envir-name mount-point |
Add the patches to the boot environment.
# /usr/sbin/patchadd -R mount-point -M patch-path patch-list-file-name |
In the previous command, patch-path is the path name of a directory that contains patches to add. The patch-list-file-name is the file that contains the list of patches you want to add.
Unmount the boot environment.
# luumount boot-envir-name |
