While installing the MU1, if you install a patch that supports multiple package architecture, an error similiar to the following benign error message might be displayed in the //var/sadm/install_data/Maintenance_Update_log.
Installing xxxxxx-yy (x of xx) See //var/sadm/patch/xxxxxx-yy log for details grep: can't open pdgabbrev.extension/pkginfo |
For example, if patch 123456-01 contains the following patch packages:
SUNWcar
SUNWcar.u
grep: can't open SUNWcar.u/pkginfo |
Workaround: Ignore the error message. The message does not affect the installation of the patch. The message indicates that patchadd(1M) doesn't pass the correct parameter to the remove_PATCH_PROPERTIES() function.
