To lock an entire file, set the offset to zero and set the size to zero.
You can set a lock on a file in several ways. The choice of method depends on how the lock interacts with the rest of the program, performance, and portability. This example uses the POSIX standard-compatible fcntl(2) interface. The interface tries to lock a file until one of the following happens:
The file lock is set successfully.
An error occurs.
MAX_TRY is exceeded, and the program stops trying to lock the file.
#include <fcntl.h> ... struct flock lck; ... lck.l_type = F_WRLCK; /* setting a write lock */ lck.l_whence = 0; /* offset l_start from beginning of file */ lck.l_start = (off_t)0; lck.l_len = (off_t)0; /* until the end of the file */ if (fcntl(fd, F_SETLK, &lck) <0) { if (errno == EAGAIN || errno == EACCES) { (void) fprintf(stderr, "File busy try again later!\n"); return; } perror("fcntl"); exit (2); } ...
Using fcntl(2), you can set the type and start of the lock request by setting structure variables.
You cannot lock mapped files with flock(3UCB). However, you can use the multithread-oriented synchronization mechanisms with mapped files. These synchronization mechanisms can be used in POSIX styles as well as in Soalris styles. See the mutex(3THR), condition(3THR), semaphore(3THR), mmap(2), and rwlock(3THR) man pages.
