The meminfo() function gives the calling process information about the virtual memory and physical memory that the system has allocated to that process.
#include <sys/types.h>
#include <sys/mman.h>
int meminfo(const uint64_t inaddr[], int addr_count,
const uint_t info_req[], int info_count, uint64_t outdata[],
uint_t validity[]);
The meminfo() function can return the following types of information:
The physical memory address corresponding to the given virtual address.
The lgroup to which the physical page corresponding to the given virtual address belongs.
The size of the physical page corresponding to the given virtual address.
The number of replicated physical pages that correspond to the given virtual address.
The nth physical replica of the given virtual address.
The lgroup to which the nth physical replica of the given virtual address belongs.
The lgroup to which the given physical address belongs.
The meminfo() function takes the following parameters:
An array of input addresses.
The number of addresses that are passed to meminfo().
An array listing the types of information that are being requested.
The number of pieces of information that are requested for each address in the inaddr array.
An array where the meminfo() function places the results. The array's size is equal to the product of the values of the info_req and addr_count parameters.
An array of size equal to the value of the addr_count parameter. The validity array contains bitwise result codes. The 0th bit of the result code evaluates the validity of the corresponding input address. Each successive bit in the result code evaluates the validity of the response to the members of the info_req array in turn.
The meminfo() function returns EFAULT when the area of memory that the outdata or validity arrays point to cannot be written to. The meminfo() function returns EFAULT when the area of memory that the info_req or inaddr arrays point to cannot be read from. The meminfo() function returns EINVAL when the value of info_count exceeds 31 or is less than 1. The meminfo() function returns EINVAL when the value of addr_count is less than zero.
void
print_info(void **addrvec, int how_many)
static const int info[] = {
MEMINFO_VPHYSICAL,
MEMINFO_VPAGESIZE};
uint64_t * inaddr = alloca(sizeof(uint64_t) * how_many);
uint64_t * outdata = alloca(sizeof(uint64_t) * how_many * 2;
uint_t * validity = alloca(sizeof(uint_t) * how_many);
int i;
for (i = 0; i < how_many; i++)
inaddr[i] = (uint64_t *)addr[i];
if (meminfo(inaddr, how_many, info,
sizeof (info)/ sizeof(info[0]),
outdata, validity) < 0)
for (i = 0; i < how_many; i++) {
if (validity[i] & 1 == 0)
printf("address 0x%llx not part of address
space\n",
inaddr[i]);
else if (validity[i] & 2 == 0)
printf("address 0x%llx has no physical page
associated with it\n",
inaddr[i]);
else {
char buff[80];
if (validity[i] & 4 == 0)
strcpy(buff, "<Unknown>");
else
sprintf(buff, "%lld", outdata[i * 2 +
1]);
printf("address 0x%llx is backed by physical
page 0x%llx of size %s\n",
inaddr[i], outdata[i * 2], buff);
