Applications must call lgrp_init() in order to use the APIs for traversing the lgroup hierarchy and discover the contents of the lgroup hierarchy. The call to lgrp_init() gives the application a consistent snapshot of the lgroup hierarchy. The application developer can specify whether the snapshot contains only the resources available to the calling thread specifically or the resources available to the operating system in general. The lgrp_init() function returns a cookie that is used for the following tasks:
Navigating the lgroup hierarchy
Determining the contents of an lgroup
Determining whether or not the snapshot is current
The lgrp_init() function initializes the lgroup interface and takes a snapshot of the lgroup hierarchy.
#include <sys/lgrp_user.h> lgrp_cookie_t lgrp_init(lgrp_view_t view);
When the lgrp_init() function is called with LGRP_VIEW_CALLER as the view, the function returns a snapshot that contains only the resources available to the calling thread. When the lgrp_init() function is called with LGRP_VIEW_OS as the view, the function returns a snapshot that contains the resources that are available to the operating system. When a thread successfully calls the lgrp_init() function, the function returns a cookie that is used by any function that interacts with the lgroup hierarchy.
The lgroup hierarchy consists of a root lgroup that contains all of the machine's CPU and memory resources. The root lgroup may contain other locality groups defined by bounded latency intervals.
The lgrp_init() function can return two errors. When a view is invalid, the function returns EINVAL. When there is insufficient memory to allocate the snapshot of the lgroup hierarchy, the function returns ENOMEM.
The lgrp_fini() function ends the usage of a given cookie and frees the corresponding lgroup hierarchy snapshot.
#include <sys/lgrp_user.h> int lgrp_fini(lgrp_cookie_t cookie);
The lgrp_fini() function takes a cookie which represents an lgroup hierarchy snapshot created by a previous call to lgrp_init(). The lgrp_fini() function frees the memory that is allocated to that snapshot. After the call to lgrp_fini(), the cookie is invalid. Do not use that cookie again.
When the cookie passed to the lgrp_fini() function is invalid, lgrp_fini() returns EINVAL.
