The key interconnect data required for export operations and import operations are:
Export cluster node ID
Import cluster node ID
Controller name
An application component that exports memory can use the data provided by the interface to find the set of existing local controllers. The data provided by the interface can also be used to correctly assign controllers for the creation and publishing of segments. Application components can efficiently distribute exported segments over the set of controllers that is consistent with the hardware interconnect and with the application software distribution.
An application component that is importing memory must be informed of the segment IDs and controllers used in the memory export. This information is typically conveyed by a predefined segment and controller pair. The importing component can use the topology data to determine the appropriate controllers for the segment import operations.
This function returns a pointer to the topology data in a location specified by an application pointer. The topology data structure is defined next.
Return Values: Returns 0 if successful. Returns an error value otherwise.
Invalid topology pointer
Insufficient memory
Insufficient memory
The rsm_free_interconnect_topology operation frees the memory allocated by rsm_get_interconnect_topology.
Return Values: None.
The pointer returned from rsm_get_topology_data references a rsm_topology_t structure. This structure provides the local node ID and an array of pointers to a connections_t structure for each local controller.
typedef struct rsm_topology {
rsm_nodeid_t local_nodeid;
uint_t local_cntrl_count;
connections_t *connections[1];
} rsm_topology_t;
