A Web Start Flash archive contains archive identification information in addition to the actual files from the master system that will be installed on the clone systems. You are required to specify a name for the Web Start Flash archive. Other information that you can specify about the archive includes:
The author of the archive
The date the archive was created
The name of the master system that you used to create the archive
For a complete list of the archive identification information that you can specify, refer to "Identification Section Keywords".
Use the flar command to retrieve information about the archive. For detailed instructions, refer to "flar".
