The final task in the Web Start Flash installation process is to install Web Start Flash archives on clone systems.
You can use any of the Solaris installation methods to install Web Start Flash archives on clone systems.
The Solaris Web Start program on the Solaris 9 DVD or Solaris 9 Installation CD enables you to install Web Start Flash archives that are stored on the following:
Disc (DVD or CD)
NFS server
HTTP server
FTP server
Local tape
The Solaris suninstall program on the Solaris 9 Software 1 of 2 CD enables you to install Web Start Flash archives that are stored on the following:
HTTP server
FTP server
NFS server
Local file
Local tape
Local device, including CD
The custom JumpStart installation program enables you to install Web Start Flash archives that are stored on the following:
NFS server
HTTP server
FTP server
Local tape
Local device, including DVD or CD
Local file
Solaris Live Upgrade enables you to install Web Start Flash archives that are stored on the following:
HTTP server
FTP server
NFS server
Local file
Local tape
The Web Start Flash installation feature provides the ability to layer Web Start Flash archives. You can create partial Web Start Flash archives to install in a variety of ways.
For example, you can create one archive that contains the Solaris operating environment files, a second archive that contains the files necessary to run a Web server, and a third archive that contains the files for an NFS server. You can install the first and second archives to a system in order to create a Web server. You can install the first and third archives to another system in order to create an NFS server.
By using layered archives, you can increase the flexibility of the Web Start Flash installation while you reduce the disk space that is required to store Web Start Flash archives. When you install layered archives to a clone system, one of the archives must contain the Solaris operating environment.
If you use layered Web Start Flash archives to install additional software on clone systems separately from the Solaris operating environment, the Solaris package database has no record of the additional software.
