Solaris 9 Installation Guide
Profile Keywords at a Glance
Table 28-2 provides a quick way to determine which keywords you can use, based on your installation scenario. Unless otherwise noted in the keyword descriptions, the keyword can only be used with the initial installation option.
Table 28-2 Overview of Profile Keywords
Installation Scenarios
Profile Keywords
Standalone System (Non-Networked)
Standalone System (Networked) or Server
OS Server
Upgrade
Upgrade With Disk Space Reallocation
archive_location
v
v
backup_media
v
boot_device
v
v
v
client_arch
v
client_root
v
client_swap
v
cluster (adding software groups)
v
v
v
cluster (adding or deleting clusters)
v
v
v
v
v
dontuse
v
v
v
filesys (mounting remote file systems)
v
v
filesys (creating local file systems)
v
v
v
geo
v
v
v
v
v
install_type
v
v
v
v
v
isa_bits
v
v
v
v
v
layout_constraint
v
locale
v
v
v
v
v
num_clients
v
package
v
v
v
v
v
partitioning
v
v
v
root_device
v
v
v
v
v
system_type
v
v
v
usedisk
v
v
v
