The lucreate command used with the -m option specifies which file systems and the number of file systems to be created in the new boot environment. You must specify the exact number of file systems you want to create by repeating this option. For example, a single use of the -m option specifies where to put all the file systems. You merge all the file systems from the original boot environment into one file system. If you specify the -m option twice, you create two file systems.
Log in as superuser.
Type:
# lucreate [[-A 'BE_description']] -m mountpoint:device:fs_type \ [[-m mountpoint:device:fs_type]] -m mountpoint:merged:fs_type -n BE_name |
In this example, the file systems on the current boot environment are root (/), /usr, and /opt. The /opt file system is combined with its parent file system /usr. The new boot environment is named second_disk. A description, Solaris 9 test Jan. 2001, is associated with the name second_disk.
# lucreate -A 'Solaris 9 test Jan 2001' -c first_disk \ -m /:/dev/dsk/c0t4d0s0:ufs -m /usr:/dev/dsk/c0t4d0s1:ufs \ -m /usr/opt:merged:ufs -n second_disk |
When creation of the new boot environment is complete, it can be upgraded and activated (made bootable). See Chapter 33, Upgrading With Solaris Live Upgrade (Tasks).
