Log in as superuser.
Type:
# /usr/sbin/lucompare -i infile (or) -t -o outfile BE_name |
-i infile |
Compare files that are listed in infile. The files to be compared should be an absolute file name. If the entry in the file is a directory, then comparison is recursive to the directory. Use either this option or -t, not both. |
-t |
Compare only nonbinary files. This comparison uses the file(1) command on each file to determine if the file is a text file. Use either this option or -i, not both. |
-o outfile |
Redirect the output of differences to outfile. |
BE_name |
Specifies the name of the boot environment that is compared to the active boot environment. |
In this example, first_disk boot environment (source) is compared to second_disk boot environment and the results are sent to a file.
# /usr/sbin/lucompare -i /etc/lu/compare/ \ -o /var/tmp/compare.out second_disk |
