Insert the Solaris 9 DVD or Solaris 9 Software 2 of 2 CD.
Run the installer for the media you are using.
If you are using the Solaris 9 DVD, change directories to the installer and run the installer.
# cd /cdrom/cdrom0/Solaris_9/Tool/Installers # ./liveupgrade20 |
The Solaris Web Start installer is displayed.
If you are using the Solaris 9 Software 2 of 2 CD, run the installer.
% ./installer |
From the Select Type of Install panel, click Custom.
On the Locale Selection panel, click the language to be installed.
Choose the software to install.
For DVD, on the Component Selection panel, click Next to install the packages.
For CD, on the Product Selection panel, click Default Install for Solaris Live Upgrade and click on the other software choices to deselect them.
Follow the directions on the Solaris Web Start installer panels to install the software.
