Solaris 9 Installation Guide
To Preconfigure the Locale Using NIS+
The following procedure assumes the NIS+ domain is set up. Setting up the NIS+ domain is documented in the System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
  1. Log in to a name server as superuser or as a user in the NIS+ administration group.
  2. Create the locale table:
    # nistbladm -D access=og=rmcd,nw=r -c locale_tbl name=SI,nogw=
    locale=,nogw= comment=,nogw= locale.org_dir.`nisdefaults -d`
  3. Add needed entries to the locale.
    # nistbladm -a name=name locale=locale comment=comment
    name
    Either the domain name or a specific system name for which you want to preconfigure a default locale.
    locale
    The locale you want to install on the system and use on the desktop after the system is rebooted. Chapter 40, Locale Values (Reference) contains a list of valid locales.
    comment
    The comment field. Use double quotation marks to begin and end comments that are longer than one word.
    Note -
    Locales are available on the Solaris 9 DVD or Solaris 9 Software 1 of 2 CD.
    Systems that are specified by domain or individually in the locale table are now set up to use the default locale. The default locale you specified is used during installation and by the desktop after the system is rebooted.
