cluster group_name |
cluster designates the software group to add to the system. The group_name for each software group is listed in the following table.
Software Group | group_name |
Core | SUNWCreq |
End User Solaris Software Group | SUNWCuser |
Developer Solaris Software Group | SUNWCprog |
Entire Solaris Software Group | SUNWCall |
Entire Solaris Software Group Plus OEM Support | SUNWCXall |
You can specify only one software group in a profile. The software group must be specified before other cluster and package entries. If you do not specify a software group with cluster in the profile, the end-user software group, SUNWCuser, is installed on the system.
