The following example shows how to use pfinstall to test a profile that is named basic_prof. The profile is tested against the disk configuration on a system on which the Solaris 9 software is installed. The basic_prof profile is located in the /jumpstart directory, and the path to the Solaris 9 Software 1 of 2 CD image is specified because Volume Manager is being used.
# cd /jumpstart # /usr/sbin/install.d/pfinstall -D -c /cdrom/pathname basic_prof |
The following example shows how to use pfinstall to test the profile that is named basic_prof on a Solaris 9 system. The test is performed against the 535_test disk configuration file. The test checks for 64 Mbytes of system memory. This example uses a Solaris 9 Software 1 of 2 CD image that is located in the /export/install directory.
# SYS_MEMSIZE=64 # export SYS_MEMSIZE # /usr/sbin/install.d/pfinstall -d 535_test -c /export/install basic_prof |
