install_type initial_upgrade_flash_swith |
install_type defines whether to erase and install a new Solaris operating environment on a system, upgrade the existing Solaris environment on a system, or install a Web Start Flash archive on the system.
You must specify install_type in a profile, and install_type must be the first profile keyword in every profile.
You must use one of the following options for the initial_upgrade_flash_switch:
initial_install - Specifies to perform an initial installation of the Solaris operating environment
upgrade - Specifies to perform an upgrade of the Solaris operating environment
flash_install - Specifies to install a Web Start Flash archive
Some profile keywords can only be used with the initial_install option. Some profile keywords can only be used with the upgrade option. Some profile keywords can only be used with the flash_install option.
