When using Solaris Live Upgrade while upgrading and running Veritas VxVM, the system panics on reboot unless you upgrade by using the following procedure. The problem occurs if packages do not conform to Solaris advanced packaging guidelines.
Create an inactive boot environment. See "Creating a New Boot Environment".
Before upgrading the inactive boot environment, you must disable the existing Veritas software on the inactive boot environment.
Mount the inactive boot environment.
# lumount inactive_boot_environment_name mount_point |
For example:
# lumount solaris8 /.alt.12345 |
Change to the directory that contains the vfstab, for example:
# cd /.alt.12345/etc |
Make a copy of the inactive boot environment's vfstab file, for example:
# cp vfstab vfstab.501 |
In the copied vfstab, comment out all Veritas file system entries, for example:
# sed vfstab.novxfs > vfstab < '/vx\/dsk/s/^/#/g' |
The first character of each line is changed to #, which makes the line a comment line. Note that this comment line is different than the system file comment lines.
Copy the changed vfstab file, for example:
# cp vfstab.novxfs vfstab |
Change directories to the inactive boot environment's system file, for example:
Make a copy of the inactive boot environment's system file, for example:
# cp system system.501 |
Comment out all "forceload:" entries that include drv/vx.
# sed '/forceload: system.novxfs > system < drv\/vx/s/^/*/' |
The first character of each line is changed to *, which makes the line a command line. Note that this comment line is different than the vfstab file comment lines.
Change directories to the install-db file on the inactive boot environment, for example:
Create the Veritas install-db file, for example:
# touch vx/reconfig.d/state.d/install-db |
Unmount the inactive boot environment.
# luumount inactive_boot_environment_name mount_point |
Upgrade the inactive boot environment. See Chapter 33, Upgrading With Solaris Live Upgrade (Tasks).
Activate the inactive boot environment. See "Activating a Boot Environment".
Shut down the system.
# init 0 |
Boot the inactive boot environment in single-user mode:
OK boot -s |
Several messages and error messages that contain "vxvm" or "VXVM" are displayed that can be ignored. The inactive boot environment becomes active.
Upgrade Veritas.
Restore the original vfstab and system files:
# cp /etc/vfstab.original /etc/vfstab # cp /etc/system.original /etc/system |
Reboot the system.
# init 6 |
