Retrieve the failed network information from the failure error message of the console log.
See the syslog(3C) man page. The error message might be similar to the following message:
moving addresses from failed IPv4 interfaces: hme1 (moved to hme0) |
The error message might also be similar to the following message:
moving addresses from failed IPv4 interfaces: hme1 (couldn't move, no alternative interface) |
Attach the physical interface to the system.
Refer to the cfgadm(1M) man page, Sun Enterprise 10000 DR Configuration Guide, or Sun Enterprise 6x00, 5x00, 4x00, and 3x00 Systems Dynamic Reconfiguration User's Guide for a description of how to replace the physical interface.
Refer to the message content from step 1. If the addresses could not be moved, go to step 5. If the addresses were moved, do step 4.
Unplumb the logical interfaces that are configured as part of the failover process by doing the following substeps.
Look at the contents of the file /etc/hostname.<moved_from_interface> to see what logical interfaces were configured as part of the failover process.
Unplumb each failover IP address by typing the following command:
# ifconfig moved_to_interface removeif moved_ip_address |
Failover addresses are those addresses that are marked with the failover parameter, or those addresses that are not marked with the -failover parameter. You do not need to unplumb IP addresses that are marked -failover.
For example, assume that the contents of the /etc/hostname.hme0 file contained the following lines:
inet 1.2.3.4 -failover up group one addif 1.2.3.5 failover up addif 1.2.3.6 failover up |
Then, to unplumb each failover IP address, you would type the following commands:
# ifconfig hme0 removeif 1.2.3.5 # ifconfig hme0 removeif 1.2.3.6 |
Reconfigure the IPv4 information for the replaced physical interface by typing the following command for each interface that was removed.
# ifconfig removed_from_NIC <parameters> |
By using the example in step 4, you would type the following commands:
# ifconfig hme1 inet plumb # ifconfig hme1 inet 1.2.3.4 -failover up group one # ifconfig hme1 addif 1.2.3.5 failover up # ifconfig hme1 addif 1.2.3.6 failover up |
