Solaris 9 및 Solaris 9 9/02 소프트웨어의 아시아권 언어 패키지에 포함된 preremove 스크립트가 Disk Space Reallocation(DSR)으로 업그레이드 동안 제대로 실행되지 않습니다. Solaris 운영 환경의 최신 릴리스로 업그레이드하려고 시도하면 다음 오류 메시지가 /var/sadm/system/logs/update_log 파일에 표시됩니다.
Removing package SUNWkwbcp: /a/var/sadm/pkg/SUNWkwbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWkwbcp failed. pkgrm return code = 1 Removing package SUNWkbcp: /a/var/sadm/pkg/SUNWkbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWkbcp failed. pkgrm return code = 1 Removing package SUNWcwbcp: /a/var/sadm/pkg/SUNWcwbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWcwbcp failed. pkgrm return code = 1 Removing package SUNWcbcp: /a/var/sadm/pkg/SUNWcbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWcbcp failed. pkgrm return code = 1 Removing package SUNWhwbcp: /a/var/sadm/pkg/SUNWhwbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWhwbcp failed. pkgrm return code = 1 Removing package SUNWhbcp: /a/var/sadm/pkg/SUNWhbcp/install/preremove: /a/usr/4lib: does not exist pkgrm: ERROR: preremove script did not complete successfully Removal of SUNWhbcp failed. pkgrm return code = 1 |
조치: 이 오류 메시지를 무시하십시오.
