The mconnect program opens a connection to a mail server on a host that you specify and enables you to test that connection. The program runs interactively, so you can issue various diagnostic commands. See the mconnect(1) man page for a complete description. The following example verifies that mail to the user name sandy is deliverable.
% mconnect phoenix onnecting to host phoenix (172.31.255.255), port 25 connection open 220 phoenix.example.com ESMTP Sendmail 8.12.0+Sun/8.12.0;Sun, 4 Sep 2001 3:52:56 -0700(PDT) expn sandy 250 2.1.5 <sandy@phoenix.example.com> quit |
If you cannot use mconnect to connect to an SMTP port, check these conditions.
Is the system load too high?
Is the sendmail daemon running?
Does the system have the appropriate /etc/mail/sendmail.cf file?
Is port 25 (the port that sendmail uses) active?
