System Administration Guide: Resource Management and Network Services
Local Mail Only
The simplest mail configuration, shown in Figure 25–1, is two or more workstations that are connected to one mail host. Mail is completely local. All the clients store mail on their local disks and act as mail servers. Mail addresses are parsed by using the /etc/mail/aliases files.
Figure 25–1 Local Mail Configuration
Diagram shows the dependencies of a mail host to mail clients.
To set up this kind of mail configuration, you need the following.
For task information on setting up your mail service, refer to Setting Up Mail Services (Tasks). If you are looking for a particular procedure that is related to setting up your mail service, refer to Setting Up Mail Services (Task Map).
