The Solaris 9 version of sendmail includes a configuration option that enables you to define the version of the sendmail.cf file. This option enables older configuration files to be used with the current version of sendmail. You can set the version level to values between 0 and 10. You can also define the vendor. Either Berkeley or Sun are valid vendor options. If a version level is specified but no vendor is defined, Sun is used as the default vendor setting. The following table lists some of the valid options.
Table 26–6 Configuration File Version Values|
Field |
Description |
V7/Sun |
Setting that was used for Version 8.8 of sendmail. |
V8/Sun |
Setting that was used for Version 8.9 of sendmail. This setting was included in the Solaris 8 release. |
V9/Sun |
Setting that was used for versions 8.10 and 8.11 of sendmail. |
V10/Sun |
Setting that is used for version 8.12 of sendmail. Version 8.12 is the default for the Solaris 9 release. |
You are urged not to use V1/Sun. For more information, refer to http://www.sendmail.org/vendor/sun/differences.html#4.
For task information, refer to Building the sendmail.cf Configuration File (Task) in Chapter 25, Mail Services (Tasks).
