You use the /etc/ppp/options file to define global options for all PPP communications on the local machine. /etc/ppp/options is a privileged file. /etc/ppp/options should be owned by root, although pppd does not enforce this rule. Options that you define in /etc/ppp/options have precedence over definitions of the same options in all other files and the command line.
Typical options that you might use in /etc/ppp/options include the following:
lock– Enables UUCP-style file locking
noauth – Indicates that the machine does not authenticate callers
The Solaris PPP 4.0 software does not include a default /etc/ppp/options file. pppd does not require the /etc/ppp/options file to work. If a machine does not have an /etc/ppp/options file, only root can run pppd on that machine.
You must create /etc/ppp/options by using a text editor, as shown in How to Define Communications Over the Serial Line. If a machine does not require global options, you can create an empty /etc/ppp/options file. Then, both root and regular users can run pppd on the local machine.
The /etc/ppp/options.tmpl contains helpful comments about the /etc/ppp/options file plus three common options for the global /etc/ppp/options file.
lock nodefaultroute noproxyarp |
Option |
Definition |
lock |
Enables UUCP-style file locking |
nodefaultroute |
Specifies that no default route is defined |
noproxyarp |
Disallows proxyarp |
To use /etc/ppp/options.tmpl as the global options file, rename /etc/ppp/options.tmpl to /etc/ppp/options. Then, modify the file contents as needed by your site.
Example /etc/ppp/options |
For Instructions |
For a dial-out machine | |
For a dial-in server |
How to Define Communications Over the Serial Line (Dial-in Server) |
For PAP support on a dial-in server |
How to Add PAP Support to the PPP Configuration Files (Dial-in Server) |
For PAP support on a dial-out machine |
How to Add PAP Support to the PPP Configuration Files (Dial-out Machine) |
For CHAP support on a dial-in server |
How to Add CHAP Support to the PPP Configuration Files (Dial-in Server) |
