This field specifies the maximum job size that can be entered in the queue. Job-size is measured in bytes and can be a list of the options that are listed in the following table.
Table 40–8 Job-size Field|
nnnn |
Integer that specifies the maximum job size for this job grade |
nK |
Decimal number that represents the number of kilobytes (K is an abbreviation for kilobyte) |
nM |
Decimal number that represents the number of megabytes (M is an abbreviation for megabyte) |
Keyword that specifies that no maximum job size exists |
Here are some examples:
5000 represents 5000 bytes
10K represents 10 Kbytes
2M represents 2 Mbytes
