The following table is a list of the most common STATUS error messages.
Table 40–12 UUCP STATUS Messages|
Error Message |
Description/Action |
Status is okay. |
Currently no device is available for the call. Check whether a valid device is in the Devices file for the particular system. Check the Systems file for the device to be used to call the system. |
A call was placed to the system at a time other than what is specified in the Systems file. |
Self-explanatory. |
The login for the particular machine failed. The cause could be a wrong login or password, wrong number, a slow machine, or failure in executing the Dialer-Token-Pairs script. |
The conversation failed after successful startup. This error usually means that one side went down, the program aborted, or the line (link) was dropped. |
The remote machine never answered. The cause could be a bad dialer or the wrong phone number. |
The machine called with a login/machine name that does not agree with the Permissions file. This error could be an attempt to masquerade. |
The calling device to be used is currently locked and in use by another process. |
An ASSERT error occurred. Check the /var/uucp/.Admin/errors file for the error message and refer to the section UUCP ASSERT Error Messages. |
The system is not in the Systems file. |
The device tried does not exist or the modes are wrong. Check the appropriate entries in the Systems and Devices files. |
The device could not be opened. |
The called machine is reporting a different name than expected. |
The called machine requires that it call your machine. |
The remote machine has a LCK file for your machine. The remote machine could be trying to call your machine. If it has an older version of UUCP, the process that was talking to your machine might have failed, leaving the LCK file. If the remote machine has the new version of UUCP and is not communicating with your machine, the process that has a LCK file is hung. |
The remote machine does not have the node name of your machine in its Systems file. |
The login that was used by your machine to log in does not agree with what the remote machine was expecting. |
The remote machine rejected the communication with your machine for an unknown reason. The remote machine might not be running a standard version of UUCP. |
Login succeeded, but initial handshake failed. |
This error is usually the same as DIAL FAILED. However, if this error occurs often, suspect the caller script in the Dialers file. Use Uutry to check. |
