Solaris 9 Installation Guide
Syntax of the custom_probes File
The custom_probes file can contain any valid Bourne shell command, variable, or algorithm.
Note -
You can define probe and comparison functions that require a single argument in the custom_probes file. When you use the corresponding custom probe keyword in the rules file, the argument after the keyword is interpreted (as $1).
When you use the corresponding custom rule keyword in the rules file, the argument is interpreted as starting after the keyword and ending before the next && or begin script, whichever comes first.
The custom_probes file must meet the following requirements:
To improve clarity and organization, define all probe functions first, at the top of the file, followed by all comparison functions.
