If you want to use the Solaris Flash installation method to install the Solaris software on both SPARC and IA systems, you must create a separate Solaris Flash archive for each platform. Use the Solaris Flash archive that was created from the SPARC master system to install SPARC systems. Use the Solaris Flash archive that was created from the IA master system to install IA systems.
