The final task in the Solaris Flash installation process is to install Solaris Flash archives on clone systems.
You can use any of the Solaris installation methods to install Solaris Flash archives on clone systems.
The Solaris Web Start program on the Solaris 9 DVD or Solaris 9 Installation CD enables you to install Solaris Flash archives that are stored on the following:
Disc (DVD or CD)
NFS server
HTTP server
FTP server
Local tape
For installation instructions, see “SPARC: Performing an Installation or Upgrade With the Solaris Web Start Program” or “IA: Performing an Installation or Upgrade With the Solaris Web Start Program”.
The Solaris suninstall program on the Solaris 9 Software 1 of 2 CD enables you to install Solaris Flash archives that are stored on the following:
NFS server
HTTP server
FTP server
Local file
Local tape
Local device, including CD
For installation instructions, see “SPARC: Performing an Installation or Upgrade With the Solaris suninstall Program” or “IA: Performing an Installation or Upgrade With the Solaris suninstall Program”.
The custom JumpStart installation program enables you to install Solaris Flash archives that are stored on the following:
NFS server
HTTP server
FTP server
Local tape
Local device, including DVD or CD
Local file
For installation instructions, see “To Prepare to Install a Solaris Flash Archive With a Custom JumpStart Installation”.
Solaris Live Upgrade enables you to install Solaris Flash archives that are stored on the following:
HTTP server
FTP server
NFS server
Local file
Local tape
For installation instructions, see “Installing Solaris Flash Archives on a Boot Environment”.
