You install the master system with the software configuration that you want other systems to have. Use any of the Solaris installation methods to install the Solaris operating environment on the master system.
Identify the system configuration that you want to install.
With the use of the Solaris installation methods, install the Solaris operating environment on the master system. For a discussion of the different installation methods, refer to Chapter 3, Choosing a Solaris Installation Method (Overview).
Customize your Solaris installation in any of the following ways:
Delete software
Add software
Modify configuration files
Add support for peripheral devices on the clone system
