Decide if you want to install the software by using the CD-ROM drive or by using a net image.
If you're using a CD-ROM drive, insert the Solaris 9 Software 1 of 2 Intel Platform Edition CD.
If you're using a net image, change directories to where the installation media is located. You might need to check with your network administrator for the location. The following command is an example.
% cd /net/install-svr/export/s9/ia |
Decide how to boot the system.
If you boot from the Solaris 9 Installation CD, insert the CD. Your system's BIOS must support booting from a CD.
If you boot from the network, use Pre-boot eXecution Environment (PXE) network boot. The system must support PXE. Enable the system to use PXE by using the system's BIOS setup tool or the network adapter's configuration setup tool.
If you boot from a diskette, insert the Solaris 9 Device Configuration Assistant Intel Platform Edition diskette into the system's diskette drive.
You can copy the Device Configuration Assistant software to a diskette by the following methods:
Copy the software to a diskette from the Solaris 9 Intel Platform Edition DVD or Solaris 9 Software 2 of 2 Intel Platform Edition CD by using this procedure: Appendix E, IA: Preparing to Boot From the Solaris 9 Device Configuration Assistant or the Network (Tasks).
Download and copy the software to a diskette from the Solaris Developer Connection at soldc.sun.com/support/drivers/dca_diskettes.
Boot the system by shutting it down and then turning it off and on.
A memory test and hardware detection are executed. The screen refreshes.
If you are using the Solaris 9 Software 1 of 2 Intel Platform Edition CD and Solaris 9 Software 2 of 2 Intel Platform Edition CDs, the following message appears.
SunOS - Intel Platform Edition Primary Boot Subsystem, vsn 2.0 |
Then, information similar to the following test appears.
SunOS Secondary Boot version 3.00
Solaris Intel Platform Edition Booting System
Running Configuration Assistant...
If you are using PXE network boot to boot from the network, the following message appears.
Solaris network boot... |
Then, information similar to this appears.
If you are using the Solaris 9 Device Configuration Assistant Intel Platform Edition diskette, the following appears.
Solaris Boot Sector Version 1 |
Then, information similar to the following text appears.
Solaris for x86 - FCS DCB Version 1.242
loading /solaris/boot.bin
The screen refreshes and information similar to the following text appears.
When the Solaris Device Configuration Assistant screen appears, press F2_Continue.
The Bus Enumeration screen appears with the message:
Determining bus types and gathering hardware configuration data ... |
The Scanning Devices screen appears. System devices are scanned. When scanning is complete, the Identified Devices screen appears.
Decide if you need to make any changes.
Press F2_Continue to make no changes.
Select changes and press F4.
The Loading screen appears and contains messages about drivers that are loaded to boot your system. After a few seconds, the Boot Solaris screen appears.
On the Boot Solaris screen, select CD, Net, or Disk and press F2_Continue.
The Solaris suninstall program checks the default boot disk for the requirements to install or upgrade the system.
If you are prompted, answer the system configuration questions.
If you preconfigured all of the system configuration information, proceed to Step 8.
If you did not preconfigure the system configuration information, use the “Worksheet for Installation” or the “Worksheet for Upgrading” to help you answer the system configuration questions.
After a few seconds, the Solaris Installation Program screen appears.
Press F2_Continue.
The kdmconfig – Introduction screen appears.
Press F2_Continue.
The kdmconfig - View and Edit Window System Configuration screen appears.
(Optional) Examine the configuration information on the kdmconfig - View and Edit Window System Configuration screen and make any changes you need.
When you are finished, select No changes needed - Test/Save and Exit, and press F2_Continue.
The kdmconfig Window System Configuration Test screen appears.
Press F2_Continue.
The screen refreshes and the kdmconfig Window System Configuration Test palette and pattern screen appears.
Move the pointer and examine the colors that are shown on the palette to ensure that they are displayed accurately.
If the colors do not display accurately, click No. If possible, press any key on the keyboard, or wait until kdmconfig exits the kdmconfig Window System Configuration Test screen automatically. Repeat Step 10 through Step 13 until the colors are displayed accurately and you can move the pointer as expected.
If the colors display accurately, click Yes.
The Solaris suninstall program begins.
If you are prompted, answer any remaining system configuration questions.
If you preconfigured all of the system configuration information, the Solaris suninstall program does not prompt you to enter any configuration information.
Decide if you want to reboot the system automatically and if you want to automatically eject the disc.
If you are using PXE from a network to boot, select manual reboot. You must ensure that the system does not boot from the network when it reboots. To disable network boot, during the reboot use the system's BIOS setup tool or network adapter's configuration setup tool.
Follow the instructions on the screen to install the Solaris software on the system.
If you are not installing a Solaris Flash archive, complete the installation. If you are upgrading or need to install additional software, proceed to Step 17.
When the Solaris suninstall program finishes installing the Solaris software, the system reboots automatically or prompts you to reboot manually.
After the installation is finished, installation logs are saved in a file. You can find the installation logs in the following directories:
/var/sadm/system/logs
/var/sadm/install/logs
If you are installing a Solaris Flash archive, continue.
On the Flash Archive Retrieval Method screen, select the location of the Solaris Flash archive.
The Solaris suninstall program installation prompts you to proceed, depending on the media you selected.
Type the information that you are prompted to enter.
Media Selected |
Prompt |
HTTP |
Specify the URL and proxy information that is needed to access the Solaris Flash archive. |
FTP |
Specify the FTP server and the path to the Solaris Flash archive. Specify the user and password information that allows you access to the FTP server. Specify any proxy information that is needed to access the FTP server. |
Network File System |
Specify the path to the network file system where the Solaris Flash archive is located. You can also specify the archive file name. |
Local file |
Specify the path to the local file system where the Solaris Flash archive is located. |
Local tape |
Specify the local tape device and the position on the tape where the Solaris Flash archive is located. |
Local device |
Specify the local device, the path to the Solaris Flash archive, and the type of file system on which the Solaris Flash archive is located. |
On the Flash Archive Selection screen, you can install an additional Solaris Flash archive by selecting New. If you do not want to install additional archives, press Continue to complete the installation.
If you are upgrading the Solaris software, you might need to correct some local modifications that were not preserved. For detailed instructions, refer to “Solaris suninstall Program Post-Upgrade Task”.
(Optional) To install additional software, refer to System Administration Guide: Basic Administration.
